MBSSID settings
We are unable to set the MBSSIDs in Cisco catalyst 9120 AXI-D, Could you help us to set MBSSIDs?
Rich R
Are you referring to the Multiple BSSID information element?  (you really need to be specific about what you're asking because as per above because MBSSID is also just a generic term for an AP broadcasting multiple SSIDs).
If it's the element you're referring to then most older drivers (certainly pre-802.11ax) will either not recognise it or will not see the SSID at all.  Even some earlier ax drivers won't work correctly.  So best not to enable it if your WiFi must support anything but the very latest clients otherwise you're likely to disrupt clients.  Some discussion on config here previously: https://community.cisco.com/t5/wireless/cisco-9130axe-how-to-configure-multiple-bssid/td-p/4432060
Some detailed discussion about the element here: https://www.intuitibits.com/2021/08/24/the-multiple-bssid-element-improving-airtime-efficiency/
Basically you're normally only going to see it on 6GHz where it's now mandatory so all clients should support it.
Note 9120 AP does not support the 6GHz band.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
  Multiple Basic Service Set Identifier (MBSSID) is not any special feature, it is just one AP propagating  more then one SSID. The SSID is represented by an Mac Address to differentiate each other and actually is to that Mac address that clients connect.
 When you say you are not able to enable MBSSID I understand you are not able to enable SSID at all.
Is this an autonomous AP or it is plugged to some WLC?  Can you share the config here?
We are able to create SSID and the same is broadcasting as well , but may I know how can I test the MBSSID feature and also even though I created 2 SSID's unable to see MBSSID bit in sniffer capture.
whether cisco AP supports MBSSID feature or not how to check?
Please read and understand the response from @Flavio Miranda.
Rich R
