mcs index rate
muhsi_2015
Level 3
Level 3
What is the mcs index rate here ?
Jun  8 08:18:56.327: 6842D591 r a8.2-2sa 64/62/68/68 36- 8841 030 7EE999 7D46E1 06A632 0900 q0 l224
Rasika Nayanajith
This is how you interpret it. Refer below post for more details
https://supportforums.cisco.com/document/11938046/how-interpret-80211ac-datarates
Format: aX.YcZ
X = mcs (modulation coding scheme) 0-9
Y = No of spatial streams, 1-3.
Z = Bandwidth 2, 4, 8 (2 = 20Mhz, 4=40Mhz, 8=80Mhz)
c = b for Beamform, s for STBC, - none
s = Guard Interval, indicates Short guard interval applicable over LGI (Long guard interval)
Since you got a8.2-2,
MCS 8, 2 Spatial Stream, 20MHz bandwidth.
You can work it out what is that rate is equivalent to using below index.
http://www.wlanpros.com/mcs-index-802-11n-802-11ac-chart-3/
Pls mark the thread as "answered" if you got what you looking for
Rasika
*** Pls rate all useful responses ***
