mDNS and FlexConnect
ndr_eds
Level 2
Level 2
I know that it is not possible to enable mDNS snooping and FlexConnect local switching on a WLAN at the same time. Is there anyway around this if you have FlexConnect AP's and want to alos have mDNS on your (non-flexconnect) local AP's?? Do I have to create a separate WLAN just for my FlexConnect AP's??
Thanks!
Vinoth Balu
Level 3
Level 3
one mDNS profile per WLAN
http://www.cisco.com/c/en/us/td/docs/wireless/technology/bonjour/7-5/Bonjour_Gateway_Phase-2_WLC_software_release_7-5.html
Cheers
can you elaborate more?  if I have flex connect ap,if I want to use bonjour,what can be the workaround?
