ME UI (8.5.140) with AIR-AP1815I-E-K9C : Can't switch to expert view
TonyBx
I am installing a Cisco AIR-AP1815I-E-K9C and would like to access 'Expert View' (upper right corner dedicated icon)
When clicking on this icon, nothing happenens.
I tried with many browsers (firefox, chrome, edge, IE), disabled any popup blockers as so : still no 'Expert View'.
Somebody already got the same issue ?
Any help will be welcome
anthony
Sandeep Choudhary
I would recommand to upgrade the SW version to 8.5.151.0 or 8.8.125.0
I am using 8.8.111.0 and its working.
Dont forget to arte helpful posts
Thank you for the advice. I'll try this solution.
Expert view looks the same, but some menu items will have more options. Are you sure there is no difference?
