Meraki Cameras
at@ps
Hi All,
I've been reading about Meraki camera and their features; I see that it's good product full of great features. However, I have two hot questions that I can't find out an answer for, and they are:
  • Can a Meraki camera send a notification to the admin's mobile phone once a motion is detected?
  • As Cisco mentioned that the Meraki camera stores data locally for a specific retention time, but what if a data is needed to be saved for more than the suggested retention time? OR is there an additional storage could be purchased from Cisco cloud?
I appreciate your help!
marce1000
    - Probably better post here : https://community.meraki.com/t5/Smart-Cameras/bd-p/security-cameras
 M.
Philip D'Ath
You can have it generate a email alert along with a picture showing the motion.
https://documentation.meraki.com/MV/Advanced_Configuration/Motion_Alerts#:~:text=To%20configure%20email%20recipients%2C%20go,and%20no%20other%20Meraki%20alerts.
Rather than configuring a specific retention time, most customers configure motion-based retention.  For the first 3 days, 100% of everything is kept.  After that, only motion video with motion is kept.  You can get a reasonable amount stored on camera using this method.
https://documentation.meraki.com/MV/Initial_Configuration/Video_Retention#Motion-based_retention
If you want storage off camera, you can also buy cloud archive - but it is pretty expensive, and I have never had a customer do this.
https://documentation.meraki.com/MV/Initial_Configuration/MV_Cloud_Archive
