Meraki MR44 and Aironet AP in bridge mode
yeow28
i have existing Aironet AP in my environment and have plans to add Meraki MR44 AP side by side.
would there be any issues for them to work in bridge mode so that both can work in the same office using the same set of SSID for my clients ?
Arshad Safrulla
Hi First of all there will be no seamless roaming between Meraki and Cisco environments.
Bridge mode in Meraki is some what similar to Flex Connect mode in Cisco, If your AP's are in local mode then you will be looking at a complete redesign or you may have to bring in a Meraki MX as a Wireless concentrator.
does it means that it can still work if i configure same SSID on both different AP but it will not be seamless
You will have both the AP's advertising the SSID's. But roaming from one AP to another will not be seemless. And also to add they will run their own RRM instances. SO you may have Meraki flag Cisco as rogue and vice versa.
