Meraki Wireless authentication via Auze AD
Do Meraki AP's support wireless authentication via Azure AD?
balaji.bandi
Arshad Safrulla
Let me correct Balaji here, As long as Meraki AP management VLAN has reachability to to Azure AD, you can do the integration.
Now with regards to the integration there are 2 things u need to clarify
1. Are you looking for NPS/radius integration, if this is the case you need to host Nps service in Azure AD https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_with_WPA2-Enterprise
2. If you are looking for Splash page based AD integration you may refer the below link
https://documentation.meraki.com/MR/MR_Splash_Page/Integrating_Active_Directory_with_Sign-On_Splash_Page_For_MR_Access_Points
Meraki has their own community site, you may post there as well.
