Mesh 2602i AP - One-way Neighbor
Steve Berglund
Hi everyone
I have two test AP's set up as RAP and MAP.
MAP shows the correct neighbor info, but RAP does not show anything.
I try to do a link test on the MAP, but it displays the following error -
ERROR: Cannot get stats from destination AP
Unable to perform Link Test
Backhaul 5GHz radios are on the same 40MHz channels - 64,60
Both radio roles show Downlink Access
Range - root to mesh is at default 12000
Both have the same Bridge Group name
I must be missing something somewhere. Any ideas?
Steve Berglund
I should mention the controller version is 7.6.120.
