Mesh access points with 3802e and c9800 WLC.
Kandor
[06/26/2023 17:00:02.4800] wired0: link up
[*06/26/2023 17:00:03.0260] pid 7914's current affinity mask: 3
[*06/26/2023 17:00:03.0260] pid 7914's new affinity mask: 1
[*06/26/2023 17:00:03.2193] ip6_port srcr2, ip6local fe80::a23d:6fff:fea9:8c58, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*06/26/2023 17:00:04.4111] device aptrace0 entered promiscuous mode
[*06/26/2023 17:00:04.4611] device to_container entered promiscuous mode
[*06/26/2023 17:00:04.5272] ethernet_port wired0, ip 10.5x.xx.xx, netmask 255.255.255.0, gw 10.5x.xx.xx, mtu 1500, bcast 10.58.31.255, dns1 0.0.0.0, is_static true, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*06/26/2023 17:00:05.2469] chpasswd: password for user changed
[*06/26/2023 17:00:05.7563] USB Device Disconnected from the AP
[*06/26/2023 17:00:06.1666] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Noop(0).
[*06/26/2023 17:00:06.2415] DOT11_TXP[0]:Domain configured: 0 class:A
[*06/26/2023 17:00:06.3917] DOT11_TXP[0]:Domain configured: 41 class:B
[*06/26/2023 17:00:07.5941] DOT11_TXP[0]:Domain configured: 41 class:B
[*06/26/2023 17:00:08.8448] DOT11_TXP[2]:Domain configured: 0 class:A
[*06/26/2023 17:00:09.0003] DOT11_TXP[1]:Domain configured: 41 class:B
[*06/26/2023 17:00:10.9730] DOT11_DRV[0]: Stopped Radio 0
[*06/26/2023 17:00:10.9980] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 6
[*06/26/2023 17:00:11.8780] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:11.9016] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:12.3687] DOT11_CFG[0] Radio Mode is changed from Local to Bridge
[*06/26/2023 17:00:12.3701] DOT11_CFG[1] Radio Mode is changed from Local to Bridge
[*06/26/2023 17:00:12.8783] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*06/26/2023 17:00:13.6597] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*06/26/2023 17:00:13.6775] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*06/26/2023 17:00:14.5849] DOT11_CFG[0]: Starting radio 0
[*06/26/2023 17:00:15.1579] chatter: wl0: Beacon rate info: Previous: 0 Current: 252183808
[*06/26/2023 17:00:15.1579] chatter: wl0: Beacon PID : Previous: 0 Current: 8
[*06/26/2023 17:00:15.1991] chatter: wl0: Beacon rate info: Previous: 252183808 Current: 252708096
[*06/26/2023 17:00:15.1992] chatter: wl0: Beacon PID : Previous: 8 Current: 16
[*06/26/2023 17:00:15.1992] chatter: wl0: Beacon rate info: Previous: 252708096 Current: 252970240
[*06/26/2023 17:00:15.1992] chatter: wl0: Beacon PID : Previous: 16 Current: 20
[*06/26/2023 17:00:15.5077] DOT11_DRV[0]: Started Radio 0
[*06/26/2023 17:00:15.5135] bftype is 6
[*06/26/2023 17:00:15.6220] DOT11_DRV[0]: Stopped Radio 0
[*06/26/2023 17:00:15.6438] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*06/26/2023 17:00:16.6709] DOT11_DRV[0]: Started Radio 0
[*06/26/2023 17:00:17.6072] DOT11_DRV[0]: Stopped Radio 0
[*06/26/2023 17:00:17.6291] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*06/26/2023 17:00:18.6456] DOT11_DRV[0]: Started Radio 0
[*06/26/2023 17:00:19.2928] failed wlconfig_commit netdev = wifi1
[*06/26/2023 17:00:19.2929] Error for wireless request "Commit changes" (8B00) :
[*06/26/2023 17:00:19.2929] SET failed on device wifi1 ; Operation not permitted.
[*06/26/2023 17:00:19.6215] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:20.2206] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:21.0073] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:21.0253] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:22.1819] DOT11_CFG[1]: Starting radio 1
[*06/26/2023 17:00:22.7730] chatter: wl1: Beacon rate info: Previous: 0 Current: 252183808
[*06/26/2023 17:00:22.7730] chatter: wl1: Beacon PID : Previous: 0 Current: 8
[*06/26/2023 17:00:22.8224] chatter: wl1: Beacon rate info: Previous: 252183808 Current: 252773632
[*06/26/2023 17:00:22.8224] chatter: wl1: Beacon PID : Previous: 8 Current: 17
[*06/26/2023 17:00:22.8725] chatter: wl1: Beacon rate info: Previous: 252773632 Current: 253035776
[*06/26/2023 17:00:22.8725] chatter: wl1: Beacon PID : Previous: 17 Current: 21
[*06/26/2023 17:00:23.5977] DOT11_DRV[1]: Started Radio 1
[*06/26/2023 17:00:23.6044] bftype is 6
[*06/26/2023 17:00:23.7269] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:23.7484] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:25.5021] DOT11_DRV[1]: Started Radio 1
[*06/26/2023 17:00:26.5031] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:26.5251] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:28.2714] DOT11_DRV[1]: Started Radio 1
[*06/26/2023 17:00:29.2639] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:29.2855] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:31.0181] DOT11_DRV[1]: Started Radio 1
[*06/26/2023 17:00:31.1082] CRIT-MeshControl: Starting Mesh with last known state:(3,36)
[*06/26/2023 17:00:31.2060] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:31.2282] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:32.6990] DOT11_DRV[1]: Started Radio 1
[*06/26/2023 17:00:33.6877] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:33.7105] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:35.1758] DOT11_DRV[1]: Started Radio 1
[06/26/2023 17:00:38.9100] nolan_usb nolan_usb.0: USB overcurrent detected
[*06/26/2023 17:00:39.1672] CRIT-MeshRadioBackhaul[1]: Set as uplink
[*06/26/2023 17:00:39.1673] CRIT-MeshAwppAdj[1][28:6F:7F:E0:5F:11]: Set as Parent - (New) channel(36) width(40)
[*06/26/2023 17:00:39.1852] DOT11_DRV[0]: Stopped Radio 0
[*06/26/2023 17:00:40.1502] DOT11_DRV[0]: Started Radio 0
[*06/26/2023 17:00:40.2126] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:40.2350] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:41.9712] DOT11_DRV[1]: Started Radio 1
[*06/26/2023 17:00:42.9721] DOT11_DRV[1]: Stopped Radio 1
[*06/26/2023 17:00:42.9946] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 36
[*06/26/2023 17:00:44.7600] DOT11_DRV[1]: Started Radio 1
[*06/26/2023 17:00:45.7522] CRIT-MeshLink: Set Root port Mac: 28:6F:7F:E0:5F:11 BH Id: 3 Port:54 Device:DEVNO_BH_R1
[*06/26/2023 17:00:46.1651] AP IPv4 Address updated from 0.0.0.0 to 10.5x.xx.xx
[*06/26/2023 17:00:46.1725] send CAPWAP ctrl msg to the socket: Socket operation on non-socket
[*06/26/2023 17:00:46.8125] CRIT-MeshSecurity: Mesh Security successful authenticating parent 28:6F:7F:E0:5F:11, informing Mesh Link
[*06/26/2023 17:00:47.6102] dtls_init: Use SUDI certificate
[*06/26/2023 17:00:47.6125]
[*06/26/2023 17:00:47.6125] CAPWAP State: Init
[*06/26/2023 17:00:47.6146]
[*06/26/2023 17:00:47.6146] CAPWAP State: Discovery
[*06/26/2023 17:00:47.6177] Discovery Request sent to 10.5x.xx.xxx, discovery type STATIC_CONFIG(1)
[*06/26/2023 17:00:47.6198] Discovery Request sent to 10.5x.xx.xxx, discovery type STATIC_CONFIG(1)
[*06/26/2023 17:00:47.6240] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*06/26/2023 17:00:47.6243]
[*06/26/2023 17:00:47.6243] CAPWAP State: Discovery
[*06/26/2023 17:00:47.6253] Discovery Response from 10.5x.xx.xxx
[*06/26/2023 17:00:47.6546] Discovery Response from 10.5x.xx.xxx
[*06/26/2023 17:00:47.6551] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*06/26/2023 17:00:48.0046] Start: RPC thread 1951489008 created.
[*06/26/2023 17:00:51.3137] CRIT-MeshLink: Notify Capwap Link Up: mac: 28:6F:7F:E0:5F:11 BH Id: 3 GW_reachable: No Roam: false
[*06/27/2023 17:20:22.0003]
[*06/27/2023 17:20:22.0003] CAPWAP State: DTLS Setup
[*06/27/2023 17:20:22.7187]
[*06/27/2023 17:20:22.7187] CAPWAP State: Join
[*06/27/2023 17:20:22.7249] Sending Join request to 10.5x.xx.xxx through port 5264
[*06/27/2023 17:20:22.7297] Join Response from 10.5x.xx.xxx
[*06/27/2023 17:20:22.7297] AC accepted join request with result code: 0
[*06/27/2023 17:20:22.7314] Received wlcType 0, timer 30
[*06/27/2023 17:20:22.8954]
[*06/27/2023 17:20:22.8954] CAPWAP State: Image Data
[*06/27/2023 17:20:22.8961] AP image version 17.3.7.36 backup 8.2.121.0, Controller 17.3.7.36
[*06/27/2023 17:20:22.8961] Version is the same, do not need update.
[*06/27/2023 17:20:22.9260] upgrade.sh: Script called with args:[NO_UPGRADE]
[*06/27/2023 17:20:22.9854] do NO_UPGRADE, part2 is active part
[*06/27/2023 17:20:22.9975]
[*06/27/2023 17:20:22.9975] CAPWAP State: Configure
[*06/27/2023 17:20:23.0188] Telnet is not supported by AP, should not encode this payload
[*06/27/2023 17:20:24.3470] Radio [2] Admininstrative state DISABLED change to ENABLED
[*06/27/2023 17:20:24.3478] Radio [1] Admininstrative state DISABLED change to ENABLED
[*06/27/2023 17:20:24.3485] Radio [0] Admininstrative state DISABLED change to ENABLED
[*06/27/2023 17:20:24.6004] Null cert id for TLV_AP_CACERTS_CONFIG_PAYLOAD
[*06/27/2023 17:20:24.6809]
[*06/27/2023 17:20:24.6809] CAPWAP State: Run
[*06/27/2023 17:20:24.7353] AP has joined controller WLC
[*06/27/2023 17:20:26.2912] DOT11_DRV[0]: Stopped Radio 0
[*06/27/2023 17:20:26.3151] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*06/27/2023 17:20:27.0686] chatter: wl0: Beacon rate info: Previous: 252970240 Current: 253624320
[*06/27/2023 17:20:27.0687] chatter: wl0: Beacon PID : Previous: 20 Current: 30
[*06/27/2023 17:20:27.4029] DOT11_DRV[0]: Started Radio 0
[*06/27/2023 17:20:28.3716] DOT11_DRV[0]: Stopped Radio 0
[*06/27/2023 17:20:28.3941] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 1
[*06/27/2023 17:20:29.4580] DOT11_DRV[0]: Started Radio 0
[*06/27/2023 17:20:30.9630] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=14, NumofPendingMsgs=7
[*06/27/2023 17:20:32.3920] Current session mode: ssh, Configured: Telnet-No, SSH-No, Console-Yes
[*06/27/2023 17:20:32.3921] Current session mode: telnet, Configured: Telnet-No, SSH-No, Console-Yes
[*06/27/2023 17:20:32.4175] Current session mode: console, Configured: Telnet-No, SSH-No, Console-Yes
[*06/27/2023 17:20:32.4552] chpasswd: password for user changed
[*06/27/2023 17:20:32.6028]
[*06/27/2023 17:20:32.6028] Same LSC mode, no action needed
[*06/27/2023 17:20:32.6028] TLV ID 2584 not found
[*06/27/2023 17:20:32.6029] TLV-DEC-ERR-1: No proc for 2584
[*06/27/2023 17:20:32.9949] CLSM[00:00:00:00:00:00]: U3 Client RSSI Stats feature is deprecated; can no longer be enabled
[*06/27/2023 17:20:33.0502] TLV ID 1356 not found
[*06/27/2023 17:20:33.0503] TLV-DEC-ERR-1: No proc for 1356
[*06/27/2023 17:20:33.1399] Got WSA Server config TLVs
[*06/27/2023 17:20:35.5510] AP tag change to ALC
[*06/27/2023 17:20:35.6103] Platform does not support BLE
[06/27/2023 17:20:36.8618] wired0 emac 0: link down
I am having a problem getting AP3802e to join and stay connected to the root bridge a mesh profile was created. Under the different mesh APs are correctly selected mesh or root in this case mesh. For some reason the AP connects then disconnects showing wired0 emac 0: link down state. Any suggestions is greatly appreciated.
Kandor
The issue has been resolved. The country code wasn't applied correctly on all fields needed.
5 Replies 5
Mark Elsen
  - What is the software version on the C9800 ? Use recent release and or try with 17.9.3 (e.g.)
 M.
 As  per the Datasheet  for this Access Point, it supports:
The AP supports the following operating modes:
Local—This is the default mode for the Cisco AP. In this mode, the AP does not serve clients
Flexconnect—Flexconnect mode for the Cisco AP.
Monitor—This is the monitor-only mode
SE-connect—Spectrum expert-only connect mode allows the AP to perform spectrum intelligence.
FlavioMiranda_4-1687942968668.gifSensor—Sensor mode for the Cisco AP.
FlavioMiranda_5-1687942968667.gifBut, to be in mesh network the AP should support bridge mode. I believe this AP will not support the mesh network.
@Flavio Miranda according to https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc118737974 mesh is supported on 3802.  The data sheets don't always get updated when new features are added/supported later.
Kandor
STP issues were causing ports to err-disable.
Kandor
