Mesh Distance from Root AP to Mesh AP
mahesh18
Level 6
Level 6
                   Hi all,
In 5508 WLC  what does this mean
Mesh Root AP  to Mesh AP  11000 Feet.
Need to understand what does Root AP  and MEsh AP mean?
IS this distance from WLC  to AP?
MAhesh
Scott Fella
It's not mesh:)
-Scott
12 Replies 12
Scott Fella
In mesh you have a RAP (root ap) and a MAP (mesh ap). The RAP is connected to the network switch and the MAP links up to the RAP using the 5ghz radio. The distance is from RAP to MAP.
-Scott
Thnks Scot
Glad to see that old posts still helps out:)
-Scott
-Scott
Scott Fella
Here is a design guide that can answer many of your questions regarding
Mesh.
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.0/design/guide/MeshAP_70.html
-Scott
Hi Scott,
Thanks for the reply.
So if we use WLC  then is it necessary to have RP in the network?
How can i check in GUI or command line if we have RP in the netwrok?
MAhesh
Scott Fella
You don't need a rap unless your doing mesh.
-Scott
Hi Scott,
How can i check in gui if we are doing mesh or not?
Scott Fella
Look at your AP model... Mesh APs are 15xx model. Also the mode of the ap would say bridge. Most mesh is for outdoor also.
-Scott
Model is AIR-CAP3502I-A-K9    and mode is local.
so does this mean no mesh right?
Scott Fella
It's not mesh:)
-Scott
Hi Scott,
Many thanks
Mahesh
RAP-to-MAP ratio—Recommended maximum ratio is 20 MAPs per RAP.
  * AP-to-AP distance—A spacing of no more than of 2000 feet (609.6 meters) between each mesh access point is recommended. When you extend the mesh network on the backhaul (no client access), use a cell radius of 1000 feet (304.8 meters).
For more clarity please go through the below link:
