Cisco 3850 WLC - Captive bypass portal
Kanes Ramasamy
Hi Team,
Good Day.
If I were to disable the captive bypass portal on the 3850, do i need to reboot the device for the command to take affect?
I have performed the config on the 5500 series WLC and i had to reboot it for the command to take affect?
Would it be the same?
Please assist.
Kanes.R
Scott Fella
Is there a command on the CA platform for this?  If so, why not try it and see. From this guide, it doesn't show any bypass commands for CA:
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-21/200565-Configure-ISE-Wireless-CWA-and-Hotspot-F.html#anc12
-Scott
-Scott
