06-23-2023 02:52 AM
Hello! I have a building where i can't run ethernet everywhere. Now i am looking into mesh. I have built a little test with two 2702I's (bridge mode) and when they are in the same room i get close to 200mbps, but when i go outside that room it drops to 2mbps. When i test to use it as a normal ap (flexconnect) and connect to it with my laptop i get the same result both inside and outside the room. I am using a vWlc and have set the power level to highest. What an be the problem?
06-23-2023 03:21 AM
How come using indoor APs with internal antennas for wireless bridge?
Have you conducted a spectrum survey to check whether the channels you are using are not busy?
06-25-2023 03:11 PM
Agree, Mesh works best with external APs or a directional antenna to the MAP.
SNR is very important in Mesh
