Migrated AIR-AP1142N-A-K9 (standalone to lightweight) - no LED's after migration
JMCNEL
Level 4
Level 4
We had several standalone AP's which was on IOS c1140-k9w7-mx.124-21a.JA1 that I migrated to lightweight AP's with image c1140-k9w8-tar.152-2.JA.tar. After the upgrade it connected with the WISM controllers without any problems and we have clients connected to them. However we have no LED lights on the AP's now.  Is this because of the migration that I lost the LED lights? Is there a setting I need to change after the upgrade to get that functionality back for troubleshooting purposes.
Leo Laohoo
Maybe the LED is turned off.  You can go to the GUI to turn it on or off.
JMCNEL
Level 4
Level 4
Reset the AP to default / reset hardware / AP will rejoin the controller / lights came back up.
I have the same issue with new APs (1131).
It's a bug or a new option ?
If it's a new option, where are we able to found it ?
Best regards
