Milliwatt output of Cisco wireless router
Murphy
Could you please tell me the wattage or milliwattage output of cisco model AIR-AP1262N-A-K9?
Travis
If you refer to the Radio antenna, this is the range value presented on the AP datasheet:
Available Transmit Power Settings
2.4 GHz
● 22 dBm (160 mW)
● 19 dBm (80 mW)
● 16 dBm (40 mW)
● 13 dBm (20 mW)
● 10 dBm (10 mW)
● 7 dBm (5 mW)
● 4 dBm (2.5 mW)
5 GHz
● 23 dBm (200 mW)
● 20 dBm (100 mW)
● 17 dBm (50 mW)
● 14 dBm (25 mW)
● 11 dBm (12.5 mW)
● 8 dBm (6.25 mW)
● 5 dBm (3.13 mW)
Leo Laohoo
By law, the maximum transmit power of any AP, regardless of manufacturer, is 100 mW (milliWatts).
Rich R
Actually the regulations vary by country and channel.  eg:
https://www.4gon.co.uk/solutions/technical_reference_section.php
https://w.wol.ph/2015/08/28/maximum-wifi-transmission-power-country/
