miscommunication between WLSE& WAPs
hanyawad
Level 3
Level 3
i have one WLSE 1130 and up to ten WAPs,5 WAPs of them in my local site and the others distributed over five branches. all of them are discovered in my WLSE 1130 but with a red sign in the tree. although i have 2 core switches 4506 are appeared with green sign in other words they are discovered and also working fine with the WLSE. so could you please tell me why the WAPs can't be managed through the WLSE. thanks!
Makar
Stephen Rodriguez
It sounds like the ap is no longer able to communicate with the WLSE. Have any changes been made to the WAN that would block SNMP?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
