wireless access point 1041
evanssh
Community Member
I have a wireless network using the cisco ap 1041 converted into the anonymous. however it seems like every morning or evening I have to attached it back to the SSID all over again. it will not give me an ip address. I also would have to put the encryption key in again. I am using WEP 40 bit. Has anyone experience this issue before?
Stephen Rodriguez
Not an issue I've seen. But I don't run WEP as it I easily cracked.
I'd switch to WPA/WPA2 personally
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
I want to ask about 1041 AP too.
How much maximum SSID's it can support? There is no information in datasheets
Maybe 16 SSID's as 1142 AP?
Thanks!
All Cisco AP support a maximum of 16 SSID. Though I would not recommend going beyond 3-4. Other wise you create your own interference.
Steve
HTH,
Steve
Amjad Abdullah
Are u sure u save config after u do configuration?
Rating useful replies is more useful than saying "Thank you"
