Mobility Anchor/Anchor Controller Design Question
belessing
Community Member
Hello world,
I have a short design question on Mobility Anchor/Anchor Controller configuration on 5508 v.7.2 :
When using multiple Mobility Anchors for a WLAN for N+1 redundancy, I understand the default behavior ot the controller is it sorts the ip addresses (lowest ip first...). Is there a possibility to prefer one Mobility Anchor (Primary / Backup WLC setup).
Thank you in advance! 🙂
Benjamin
Saravanan Lakshmanan
what you're looking for is supported on HA pair feature from 7.3 code.
stefan.angerer
Level 7
Level 7
No, unfortunately you cannot configure this.
regards
Stefan
Hello Stefan,
okay, thank you!
Benjamin
Hello Saravanan,
great idea. Thats what we`re looking for.
Benjamin
