Mobility anchor issues
sayrmatics
Hi all.
I've got 2 WiSMs running as my internal controllers and a 5508 as the anchor. the docs I've seen say to have the anchor and the internal controllers in separate mobility groups but the only time i could get them to show 'Up' under control path in the Mobility Group section was when i placed them in the same mobility group. while in separate groups with the control path showing as down i could ping between internal and anchor controllers.
apreciate your help.
George Stefanick
what code are you running on the WiSMs and the 5508 ?
i've got software version 6.0.196.0 running on both the WiSMs and the 5508.
Andrew Betz
Hi Seyi,
The WLCs will allow for you to maintain your Anchor WLCs within a seperate mobility domain.  Since mobility is operational between your two WLCs when within the same group, it is possible that there may be a slight misconfiguration.  Please take a look at the example below, and see if this helps:
Foreign WLC:
Default Mobility Domain: corp_internal
Mobility Members:
11:22:33:44:55:66 10.1.1.1 corp_internal
66:55:44:33:22:11 192.168.0.1 dmz
Anchor WLC:
Default Mobility Domain: dmz
Mobility Members:
Once you make these changes, try sending an eping and mping between WLCs.
Cheers,
Drew
