mobility controller and agent
mahir.aljubouri
Visitor
I configured a 3850 switch as a mobility controller and a 3650 switch as a mobility agent, and a light weight AP 2700 joined with no issue.
the AP joined the agent and i can push the config to it through the agent only and i cannot see it or configure it through the controller.
Is there any way that i can configure the AP via the controller ?
6 Replies 6
Ric Beeching
Level 11
Level 11
Can you post your MC/MA config? It sounds like you haven't set your MA to run off the MC (hierarchy). The APs should all appear on the MC only as well as the config only required there.
Ric
Please rate helpful / correct posts
Hi Ric
thank you very much for the quick reply this is the config for the controller and agent:
controller
ip dhcp excluded-address 10.0.0.200 10.0.0.254
ip dhcp pool VLAN777-pool
network 10.0.0.0 255.255.255.0
default-router 10.0.0.200
option 43 hex f104.0a00.00c8
dns-server 10.0.0.200
interface Vlan777
ip address 10.0.0.200 255.255.255.0
wireless mobility controller
wireless mobility controller peer-group MY-GROUP
wireless mobility controller peer-group MY-GROUP member ip 10.0.0.201 public-ip 10.0.0.201
wireless management interface Vlan777
ap group default-group
Agent
interface Vlan777
ip address 10.0.0.201 255.255.255.0
wireless mobility controller ip 10.0.0.200 public-ip 10.0.0.200
end
Thanks.
Have you activated the licensing on the MC?
What software versions are you running on each?
I assume you have restarted each unit once enabling one as MC and one as MA?
Can you do the following show commands on each:
show wireless mobility summary
show ap summary
show license right-to-use summary
Ta,
Ric
the controller is on evaluation license it can take 50 APs and its expiring in 90 days.
the version is 3.6.6 on both and yes i restarted both.
i dont have access to the switches right now but for show ap summary on controller is nothing and on the agent i can see the ap, and show wireless mobility summary i can see the controller and agent as (up up) on both and only on the agent i can see the ap and on the controller the ap field is blank.
Just to test for now I would do the following on your MC and alter it later if/when required.
license right-to-use activate apcount 50
I will try to test on my IOS-XE devices later as I can't verify anything atm either!
Ric
Hi Ric
I activated the AP count license.
Controller:
#show license right-to-use summary
License Name Type Count Period left
ipbase permanent N/A Lifetime
apcount evaluation 50 90
License Level In Use: ipbase
License Level on Reboot: ipbase
Evaluation AP-Count: Enabled
Total AP Count Licenses: 50
AP Count Licenses In-use: 1
AP Count Licenses Remaining: 49
#show wireless mobility summary
Mobility Controller Summary:
Mobility Role : Mobility Controller
Mobility Protocol Port : 16666
Mobility Group Name : SOS-GROUP
Mobility Oracle Configured Mode : Disabled
Mobility Oracle IP Address : 0.0.0.0
DTLS Mode : Enabled
Mobility Domain ID for 802.11r : 0xdd25
Mobility Keepalive Interval : 10
Mobility Keepalive Count : 3
Mobility Control Message DSCP Value : 48
Mobility Domain Member Count : 1
Link Status is Control Link Status : Data Link Status
Controllers configured in the Mobility Domain:
IP Public IP Group Name Multicast IP Link Status
10.0.0.200 N/A SOS-GROUP 0.0.0.0 N/A
Switch Peer Group Name : SOS-GROUP
Switch Peer Group Member Count : 1
Bridge Domain ID : 0
Multicast IP Address : 0.0.0.0
IP Public IP Link Status
10.0.0.201 10.0.0.201 UP : UP
show ap summary
Number of APs: 0
Global AP User Name: Not configured
Global AP Dot1x User Name: Not configured
Agent:
closet#show ap summary
Number of APs: 1
AP Name    AP Model     Ethernet MAC    Radio MAC State
test1            2702I          0000.0000.0000 0.0000
0  Registered
Mobility Agent Summary:
Mobility Role : Mobility Agent
Mobility Switch Peer Group Name : SOS-GROUP
DTLS Mode : Enabled
Switch Peer Group Members Configured : 1
The status of Mobility Controller:
10.0.0.200 10.0.0.200 UP : UP
Switch Peer Group members:
IP Public IP Data Link Status
10.0.0.201 10.0.0.201 N/A
