Mobility controller Configuration
abinaya.2.r
Level 4
Level 4
I have WS-C3650-24PS-Swith acting as Mobility controller and two Aps are registered here. The show wireless summary result shows the Ap Radios status as below. Can you tell me how to enable this radio.?
device(config-if)#do sh wireless summ
Access Point Summary
Total Up Down
802.11a/n 2 0 2
802.11b/g/n 2 0 2
All APs 2 2 0
Client Summary
Current Clients : 0
Excluded Clients: 0
Disabled Clients: 0
Rasika Nayanajith
Did you check radio band is enabled for 2.4GHz & 5GHz
SW2(config)#no ap dot11 24ghz shutdown
SW2(config)#no ap dot11 5ghz shutdown
Rasika
*** Pls rate all useful responses ***
