Mobility Error -anchor controller
Wifi_Eshwar92
Level 3
Level 3
"Mobility list has reached its limit- 72"i am getting this error while trying to add new mobility member in my anchor controller.
current members are 72. Is there any thing we can do to add new mobility member? Thanks!
Sandeep Choudhary
Controller software release 5.1 or later releases support up to 72 controllers in a controller’s mobility list and seamless roaming across multiple mobility groups.
Its a hardware coding so you cant do anything about it.
Dont forget to rate helpful posts
RichardAtkin
Level 8
Level 8
Nope, hard limit I believe.
what are you doing that means you need 72 controllers in a single mobility domain?!
Sandeep Choudhary
