Mobility Express clients not finding all Airprint printers
jmprats
Level 4
Level 4
I have a Mobility Express configuration. The controller is AP 3800 with 8.10.121. When clients are connected to the controller they can find all the Airprint printers, but when they are connected to other subordinated APs (9100,  1850) they can not find all the printers, just some of them.
The printers and the clients are all in the same vlan
mDNS snooping is disabled
Any help?
Rahul Kachalia
Please try to follow the Deployment Guide below to see if that helps. Though it is developed for FlexConnect Bonjour deployments, however the configuration guidelines remains consistent for Mobility Express:
Cisco DNA Service for Bonjour: Cisco FlexConnect Bonjour Deployment Guide (PDF - 1.6 MB)
thanks,
rahul.
Hi Rahul,
Thank you very much for responding to these queries from time to time. I really appreciate it and learning from your responses.
Pls keep doing it.
Rasika
