Mobility express controller become unreachable after changing switchport to trunk
ejdrijin1
Level 3
Level 3
Hi all,
I have a mobility express controller which it's switch port is an access port.
As soon as I change it to trunk, the controller will become unreachable.
What is the problem? I have another environment with the same APs and controller and they are all trunk ports.
Thanks.
Rasika Nayanajith
Did you check you configure ME controller management to tag vlan ? If management is on vlan X, then your trunk port native vlan should be anything other than vlan X
Rasika
*** Pls rate all useful responses ***
