Mobility Express Issue
SergioJ
Community Member
Hi, I have two Cisco 1815i AP's running ME for redundancy. Both are connected to trunk ports on a L3 switch with the following configuration on the switch side:
switchport trunk native vlan 3
switchport trunk allowed vlan 3-10
switchport mode trunk
switchport nonegotiate
spanning-tree portfast trunk
Both APs are running the ME image and one of them is set as the primary controller and preferred master and the other one is set for AP only. The problem I'm having is if both AP's are powered on, I'm able to login to the web management page but the page doesn't load completely and I cannot manage the APs. However, if I power down one of the APs, I'm able to login and manage the APs just fine. Any idea as to why this is happening?
Mark Elsen
 - Check this thread : https://community.cisco.com/t5/wireless/two-cisco-mobility-controller-on-the-same-network/td-p/3299781
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
