two cisco mobility controller on the same network ?
EdwinThoo
Frequent Visitor
Frequent Visitor
Hi all , is it possible we have two mobility controller on the same network ?
because i have installed one of the mobility controller and when i am trying to install the second mobility and it will keep sending request to join the first mobility controller..
please help.~
Scott Fella
If you are talking about Mobility Express, then no. There is only one master and the failover would be another AP that has joined and is supported as a master.  The Mobility Express guide will explain this in more detail. This is not like a WLC... ME can use all supported AP’s as a master so you might have many backups.
-Scott
Scott Fella
-Scott
