mobitlity issue
nareshgatta1986
Community Member
i have configured mobility group between 5508 (airos) to 9800 CL(IOS). its not working, i dubugged the pacckets, isee 5508 trying establish the connection 9800 teardown tunnel packets, on 9800 i see hash mismatch error. but hash value is configured correctly. Please check details below.  Please help me
5 Replies 5
Rich R
What version of code are you running at each end?
Have you gone through the guides in detail?
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html#Interreleasecontrollerroaming
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_c9800_wireless_controller-aireos_ircm_dg.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc11
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
CIsco 5800 is 8.10 and cisco9800 CL is 17.08.01. Yes, they are compatible. Cisco 9800 is virtual image
@nareshgatta1986 5800?  No such thing as far as I know.  Presume you mean 5508 as you said in the initial post?
5508 cannot possibly be running 8.10 because the last release to support 5508 was 8.5.  8.10 does not support 5508!
So do you want to check that answer?  And provide the exact release which the 5508 is running?
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn810mr7.html#supported-wlcs
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc3
Mark Elsen
  - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html , make sure software versions on the 5508 and 9800 are compatible , for that  take a look at Table 1 and the column Cisco AireOS-IRCM Interoperability. There is a special for workaround for a 5508 which has an expired mic , for that look at : https://community.cisco.com/t5/wireless/inter-release-controller-mobility-ircm-with-5508-fail-control/m-p/4274202#M225325 , (wait a few seconds until the solution-part of this particular thread appears on your screen). Always useful  is to have a configuration review of the 9800 CL too) with the CLI command : show  tech wireless , have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
With C9800-CL, you need to configure the hash value in 5508 mobility configuration. If you are using IRCM compatible code version pls check that setting as explained in below
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213913-building-mobility-tunnels-on-catalyst-98.html#anc27
Rasika
*** Pls rate all useful responses ***
