Monitor a client and send alert..through WCS
yprasannas
Is it possible to monitor a wireless client in WCS? Also send alert when client gets disconnected/connected?
Thanks!
Prasanna
sschmidt
You can use location based services to track a client.  You could also set the level of Client associated to AP and disassociated from AP to higher than Informational and trigger an alarm.  I could see that being very chatty though.
Administration > Settings > Severity Configuration sort by Alarm Category and look under client.  You would also need to make sure the controller is sending traps for this under Trap Controls.
Yes that would be chatty and send alerts for every client and not for a single client.
