Monitoring data rates on a WLC
ntramaseur
Hi All
        I would like to be able to monitor the data rates of clients on my LAPs. If the device was autonomous there is an OID to use,
OutDataRate   1.3.6.1.4.1.9.9.273.1.3.1.1.1
... but there does not appear to be one for Lightweight APs via SNMP to the WLC.
Can anyone offer a solution other than moving the APs back to autonomous?
 Well, you basically need a Cisco Prime Infrastructure to do. If you figure out how to get this information via API you may not need buy a Cisco Prime.
Bruno Dinis
I usually use Cisco Prime to monitor data rates per client.
you can choose a specific LAP, and then see which users are connected.
Select the user you want to troubleshoot and at that point you'll be able to check which MSC and data rate used.
