05-31-2024 04:19 PM - edited 05-31-2024 04:25 PM
Has anyone here successfully added new MIBs to LibreNMS for monitoring of access points? If yes, could you porvide a detailed walkthrough of what you did.
Currently adding WLC9800 to LibreNMS detects the SSIDs, but does not detect the APs connected to the WLC.
Solved! Go to Solution.
05-31-2024 10:24 PM
- FYI : https://community.librenms.org/t/cisco-cl9800-wireless-controller-support/14357
https://community.librenms.org/t/support-for-cisco-9800-wlc/15939
M.
05-31-2024 10:24 PM
M.
06-01-2024 05:16 AM
Hi @Mark Elsen ,
I have already seen those documents. What I was hoping for is that someone already had done this and created a walkthrough so I could save time and not have to read through a bunch of documentation and then create the necessary yaml and / or php files from scratch.
06-02-2024 04:05 AM - edited 06-02-2024 04:06 AM
Also from that link:
If you don’t want/cannot do it yourself, you should at least provide the required information :
https://docs.librenms.org/Support/FAQ/#faq20 50
This would allow somebody else to do the work for you.
checkmk added support for 9800 APs and clients a while back so you might want to look at the detail of their check code: https://checkmk.com/werk/12791
06-27-2024 03:07 AM
Sorry for the late reply. I got this partially working using the links that @Mark Elsen provided. Still struggling with getting the AP count to show correctly, but I am now seeing number of connected clients to the different SSIDs and network usage for the different APs. it is a little strange that I am seeing the APs and Data usage but the count is not showing...must be something with the graphing?
06-27-2024 06:39 AM
- Could be due to some interaction fault with the 9800 or setup in librenms ; make sure that the software version on the 9800 is up to date too, for instance : also note https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv44330?rfs=iqvred
M,
06-28-2024 01:27 AM
We are running a newer version than what is mentioned as the fixed release in that bug. I am leaning more towards that I have an issue with the code that I have added to LibreNMS.
06-27-2024 07:00 AM - edited 06-27-2024 07:04 AM
AP count is working fine for me on 17.9:
cLApGlobalAPConnectCount from CISCO-LWAPP-AP-MIB .1.3.6.1.4.1.9.9.513.1.3.35
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=cLApGlobalAPConnectCount&translate=Translate&submitValue=SUBMIT
