Morning problems with 1410 in dusty environment
gray.adam
I am running Video streaming over a 1410 Wireless Bridge. All was running fine as I am only pushing about 3mb/s over the link. However in the mornings the link has been failing. I am getting 1Volt over the RSSI and have perfect line of sight. I am getting the following stats for 5 seconds
Unicast Fragments sent 1774
Retries 371
Packets with one retry 219
Packets with more 67
Protocol Defers 14
Energy Detect Defers 194
I have replaced most of the hardware and am wondering if it could be the Sun reflecting of the dust in the early morning due. the connection is straight over a Mining pit about 2km across. The problem seems to have occured since increasing the number of shovels in the area.
gray.adam
Ok improved things somewhat. I have filtered out any unwanted multicasting backloading from other devices. And have let through the two multicasting camera addresses in the required direction. This has releaved the Energy Detect Defers. Retries are down to 10% by reducing the max speed to 36mb/s and by setting required for all lower speeds as the traffic I do want to let through is multi cast traffic.
For 5 seconds
unicast fragments sent 988
Retries 8
Packets with one retry 8
Packest with more than one retry 0
Protocol defers 1
Energy detect Defers 2
Still one question. How come there is so much 6mb/s traffic registered on the rx when it is not apparent in the tx on the other node
Note 1
TX 24Mbps 145,922 bytes
TX 36Mbps 1,736,390,998 bytes
Node 2
RX 6Mbps 1,196,567,040 bytes
RX 12Mbps 512 bytes
RX 18Mbps 0 bytes
RX 24Mbps 473,395 bytes
RX 36Mbps 1,555,805,839 bytes
Must be a bug cause the Host Bytes recieved is 1,740,143,367. that is near enought to node 1 packets sent.
Does anyone know the reason for this 6mb discrepancy?
And anyone else had cold moring problems?
