Mounting a 9100 series AP to tray work.
Dale2
I was wondering if there is a solution/bracket specifically for mounting and access point to a cable tray. If not what would you recommend?
Dale
Leo Laohoo
We generally use AP-BRACKET-2 if the AP is to be installed from a cable tray.
