MR30H
Billy254
Community Member
Does MR30H device support intrusion detection?
CMR
Meraki Community All-Star
I'm pretty sure that none of the MRs have IDS. MRs are intelligent wireless access points with some security features, mainly based around content access control. i.e. controlling what the wireless clients of them can access.
MXs are firewalls and with the advanced or better licensing they include many of the features you are referring to including intrusion detection.
A 'full stack' Meraki deployment would have MRs providing wireless access, MSs to connect them up, power them and allow wired device access and MXs to protect the solution from the outside world. MXs can of course also control outbound traffic. MSs do have security features to control what devices are able to use each port and how their traffic is routed and controlled.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
7 Replies 7
adam17210
Level 2
Level 2
It looks to, according to the MR30H datasheet which you can find here:
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MR30H.pdf
All Meraki AP's have support for Air Marshal.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Air_Marshal
But the better question is do they have a dedicated scanning radio, or do they have to do opportunistic scanning with their main radios? The datasheet @adam17210 linked to shows the MR30H's have a dedicated radio, which is by far the better option.
CMR
I thought @Billy254 was referring to physical security, like a server or corporate PC has, which I don't believe the MR30H has.
Philip D'Ath
The MR30H does not have IPS for general Internet traffic.
What the others are referring to is WiFi protection, but I'm not sure that s what you meant.
Yup
WIPS aka Air Marshal: yes
IPS as in Snort: no, you need an MX with an advanced license for that
Hi phylip and thanks,
Whats the alternative for that ? Which model can offer an intrusion detection patch and other security features? Whats the differnce between MR and MX models?
CMR
