MS-PEAP with windows zero configuration problem
ccr_cisco
Level 2
Level 2
Here is my configuration
1130 AP, WLSE Express (radius)
authentication : PEAP with ms-chapv2
My user database is on the WLSE.
MS-Peap works fine with my intel pro/wireless client but always failed with the integrated WZC client on XP SP2. I already patch it with KB885453 but this doesn't help.
Is there some specials parameters on the radius to make it works with WZC ?
Thanks for your help
5 Replies 5
robert.wright
Level 5
Level 5
review your log files, you may not have the client configured correctly... Possibly set the wrong certificate.
mattgraham
Community Member
Untick the option to verify certificate in the windows config. PEAP is server side, client can ignore it. Also, check if you are trying to use windows initial login - if so, machine authentication must be enabled.
Hope that helps.
k.rouwette
Community Member
I have the same problem with the integrated WZC client on XP SP2. The intel pro/wireless client works fine. You have know any solutions?
Yes I found the solution.
WZC is not CCX compatible so you have to disable or make optional cckm on the APs with this command :
authen key-manage cckm optional
Bye
Not applicable
