Showing results forĀ
Search instead forĀ
Did you mean:Ā
MSE and CMX in the same WLC solution ?
Hi All
I have been trying to find some documentation on this, but I am unable to (maybe there is a reason )
The setup is as follows.
The customer has a Cisco Wireless Solution with WLCs, Prime and a CMX - all working fine and doing what it should do.
But the customer now wants to also use Aeroscout tags.
Now Aeroscout tags and CMX (MSE10+) is not compatible ( Im hearing that it will be around Q3 this year ), only Aeroscout and MSE 8
Unfortunately we need to start using the Aeroscout tags right away.
Is there any reason why we should not be able to install a new MSE and use that in this solution for tags at the same time we still use the CMX ?
The CMX and Prime does not "talk together" (as far as I remember) , the MSE and Prime will - so no problem here would be my guess.
But both CMX and the new MSE would be "talking" to the WLC setup, I dont see why this should not be possible, but Im just afraid that I missed something ?
Any input would be greatly appreciated
/Thomas
Ric Beeching
Level 7
Level 7
I think you're spot on, particularly considering you're not integrating CMX with Prime so reducing the complexity.
I believe the WLCs support multiple instances as you could have one doing presence and another doing location.
Ric
Please rate helpful / correct posts
That was also my guess. :-) - (or most logical conclusion).
Ill set some of it up the day after tomorrow, and ill let you all know how it goes (if anyone is interested :-) )
/Thomas
Definitely keep us posted, always good to hear the solution once tested!
Everything seems to work fine. So thats a plus bonus... now you know. :-)
I dont think anyone will get into this kind of problem .. but it was an interesting case.
