MTBF for 1200 series AP
c.ong
Can an AP support Cat 6 cabling in future?
What is the MTBF for a 1200 Series AP?
Thanks.
Delon
raymong
Level 4
Level 4
The MTBF for the 1200 is 312,100 hours.
Dear Raymond,
I have another question for you. Could you help me with this?
IS the any difference between VxWorks and IOS software platform in 1200 Series Access Point?
Version 12 and above starts to support Vlan for both platform. Can I create each Vlan with different encryption key length and with TKIP and broadcast key rotation enable on a VxWorks paltform. I know IOS supports different types of profile, such as unique SSID, Encryption key length and with or without TKIP enable or Broadcast key rotation.
Thank you
Currently there is complet feature parrity between VxWorks and IOS ie anything you can do on one you can do on the other but as development moves forward this may not always be the case.
Yes each VLAN can have their own authentication scheme
