Multicast through Point to Point Bridge
I have a Pint to Point bridge set-up with two cisco AP's, and I am having trouble passing multicast/broadcast traffic through it.
Any one any suggestions?
Please rate all helpful posts. Was the issue resolved? (Mark as "Answered")
AP's are layer two devices, PIM is enabled at L3.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
12 Replies 12
Stephen Rodriguez
can you post the configs of the devices?
HTH,
Steve
HTH,
Steve
What are your phy rates set at ? Multicast is sent over the highest mandatory rate. If your bridge phy is lower than mandatory rate multicast would not tx ..
Am I off base on my comment Steve ?
aIOS uses the lowest configured mandatory rate, WLC uses the highest configured to send multicast.
If you have the 'base' config 1M would be a mandatory rate IIRC and multicast should flow.
of course if you are going across L3 boundaries, you need to make sure you PIM enable the L3 interfaces
HTH,
Steve
HTH,
Steve
+5 Steve .. thanks for the correction. I was thinking that was the case, glad you could confirm..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
no worries man.
HTH,
Steve
HTH,
Steve
The AP's are barely 25 feet apart with good line of sight. So I doubt that the the mandatory rate is the problem.
However I will try this as the last option.
Thank you
ROOT Bridge
Current configuration : 4227 bytes
version 15.2
no service pad
service password-encryption
hostname RootBr
logging rate-limit console 9
enable secret 5
no aaa new-model
no ip routing
no ip igmp snooping
ip domain name
dot11 mbssid
dot11 syslog
dot11 activity-timeout client default 300
dot11 ssid Bridge
   vlan 1
   authentication open
   authentication key-management wpa
   mbssid guest-mode dtim-period 2
   infrastructure-ssid
   wpa-psk ascii
   information-element ssidl advertisement wps
   no ids mfp client
username  privilege 15 secret 5
bridge irb
interface Dot11Radio0
ip dhcp client lease 1 0 0
no ip address
no ip route-cache
shutdown
encryption mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 20 mode ciphers aes-ccm
encryption vlan 10 mode ciphers aes-ccm
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
power client local
channel 2412
station-role root
beacon privacy guest-mode
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
no cdp enable
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 port-protected
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid Bridge
antenna gain 0
no dfs band block
no mbssid
speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
power client local
channel width 40-above
channel 5825
station-role root bridge
interface Dot11Radio1.1
no ip route-cache
no cdp enable
bridge-group 1
interface Dot11Radio1.10
no ip route-cache
no cdp enable
bridge-group 10
interface GigabitEthernet0
ip address 192.168.1.7 255.255.255.0
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.10
no ip route-cache
no cdp enable
bridge-group 10
interface BVI1
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
no cdp run
bridge 1 route ip
banner motd ^C
******************************WARNING:*********************************
Unauthorized Access to this network is prohibited by title 18 USC 2701
(a). Violators are subject to criminal and civil penalties under title 18 USC 2701
(b). Pursuant to title 18 USC section 2511
(2)(a)(1), any and all monitoring of user activity may take place on this network by the managment.
^C
line con 0
privilege level 15
password
logging synchronous
login
line vty 0 4
password
logging synchronous
login local
transport input all
line vty 5 15
password
login
transport input all
end
Non-Root Bridge
Current configuration : 4152 bytes
version 15.2
no service pad
hostname NRBR
enable secret 5
no aaa new-model
no ip routing
no ip igmp snooping
ip domain name
dot11 mbssid
dot11 syslog
dot11 ssid Bridge
   vlan 1
   authentication open
   infrastructure-ssid
   wpa-psk ascii
   no ids mfp client
bridge irb
no ip address
no ip route-cache
shutdown
antenna gain 0
channel 2412
station-role root
no ip route-cache
bridge-group 1
no ip route-cache
no cdp enable
bridge-group 10
no ip address
no ip route-cache
ssid Bridge
antenna gain 0
no mbssid
power client local
station-role non-root bridge
no ip route-cache
no cdp enable
bridge-group 1
no ip route-cache
no cdp enable
bridge-group 10
ip address 192.168.1.8 255.255.255.0
no ip route-cache
duplex auto
speed auto
no keepalive
no ip route-cache
bridge-group 1
no ip route-cache
no cdp enable
bridge-group 10
interface BVI1
no ip route-cache
ip http server
no cdp run
bridge 1 route ip
banner motd ^C
^C
line con 0
privilege level 15
password 7
logging synchronous
login
line vty 0 4
password 7
logging synchronous
login local
transport input all
line vty 5 15
password 7
login
transport input all
end
end
Try this, let's disable the port-protected under the radio interfaces.
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_4_JA/command/reference/cr34main.html#wp2448793
HTH,
Steve
HTH,
Steve
Abhishek Abhishek
Hello Ed,
As per your query i can suggest you the following solution-
To set a Point-2-Point bridge with two AP's and passing multicast/broadcast traffic throuh it yo can use WLC with highest configured multicast send rate.Also make sure that you have enabled PIM as you are going to communicate through layer 3 network. Use an IOS with lowest configured mandatory rate.
Hope this will help you.
I don't use a WLC, however I have been looking for the command to configure the multicast rate per second..
Can anyone show me the command for this?
Also how do I enable PIM on a Autonomous AP?
Lastly I will try lowering the mandatory rate.
HTH,
Steve
HTH,
Steve
OK. So I dont need PIM.
What is the command the command to increase the multicast rate per second??
Edit: Ok... So I had tried "no igmp port snooping", on the radio interfaced... However I had to do it on the trunked switchport....
Works now....
Thanks to everyone.
Really appreciate all you help.
