12-01-2022 11:14 AM
We got 6 AIR-AP2802I-A-K9 APs connected to same module of the switch is having LEDs flickering, but all are showing as registered in WLC and there is no logs in the switch also. But AP is not working for clients.
What could be the possible reasons . APs are getting POE from switch and it is showing good
Interface Admin Oper Power Device Class Max
Gi2/0/4 auto on 26.1 AIR-AP2802I-A-K9 0 60.0
Gi2/0/5 auto on 26.1 AIR-AP2802I-A-K9 4 60.0
Gi2/0/7 auto on 26.1 AIR-AP2802I-A-K9 4 60.0
Solved! Go to Solution.
12-03-2022 04:33 PM - edited 12-04-2022 02:20 AM
@Arshad Safrulla wrote:
1. Faulty cabling - You can start with TDR test. I would also check the patch panels and face plates to make sure that the cables are connected properly. you may thank @Leo Laohoo for this article How to use Time-Domain Reflectometer (TDR) - Cisco Community
Any switch on IOS-XE, particularly running 16.X.X and 17.X.X, TDR is broken. Any test results are no longer accurate nor reliable.
12-04-2022 03:07 AM
># sh cdp nei Gig 2/0/7 det
>....Power drawn: 15.400 Watts
- That seems incorrect (indeed) needs 16W or above , I also notice : Cisco AP Software, ap3g3-k9w8 Version: 8.5.137.98 , I would advise to upgrade the controller , check https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html , which will also upgrade (or sync) the access point software. Check if the problem remains in place or not.
M.
12-04-2022 05:22 AM
Agreed with a number of other comments - you're running old, special code so should be running an up to date supported release for a start.
But regardless of that: "Also when connect the same AP into a different switch module it worked ,but not on this module"
Therefore the problem is the switch - check your switch port configurations. If the configs are correct and you haven't changed anything else on the switch then you probably have a hardware failure so open a TAC case and RMA the switch.
12-01-2022 01:31 PM
What firmware is the WLC on?
12-02-2022 12:17 AM
AIR-CT8510-K9 WLC with firmware 8.5.137.98
12-02-2022 01:19 AM
I am not able to provide any assistance because the WLC is on a very old engineering "special" release.
I would, however, recommend to a later release, like 8.5MR6 or something.
12-02-2022 01:10 AM
- Reboot one of these access points and just after boot , connect to it and issue the command show logging , watch for issues reported.
M.
12-02-2022 03:09 AM
Is there any way to remote access the AP ip from switch other than console
12-02-2022 03:26 AM
Telnet or SSH
12-02-2022 03:28 AM
I tried, its not happening.
T1-EBS008-N5-NXDS-200-111# telnet 10.25.210.228 23 source 10.25.210.2 vrf CAN-WIRELESS
Trying 10.25.210.228...
12-02-2022 03:41 AM
By default, telnet and SSH access to the AP is disabled.
12-02-2022 03:44 AM
So the only option is to console to the AP directly
12-02-2022 04:02 AM
No. That is not what I said.
HINT: Look at the controller. Monitor > All APs > Detail > click the AP > Go to the Advanced Tab.
12-02-2022 03:20 AM
12-02-2022 04:25 AM
12-02-2022 04:59 AM
What happens if telnet or SSH box is ticked?
12-02-2022 07:02 AM
Post enabling telnet and SSH , telnet is not working , but ssh is working, but not able to see anything
