Multiple Building Wireless Network
ToolJob
Community Member
I am looking for a wireless solution to connect about 5-6 buildings together. All buildings are within 1500 feet of each other. I need some information
on the exact wireless hardware need to make this work.
All buildings are in line of sight of each other. All computer systems will be on same subnet and also running NetBEUI.
Im looking at the Cisco 350 Wireless bridge and want to get information
on how to have 1 main radio located where our Internet connection is distribute network access to the other 4 - 5 buildings.
Jim
phausner
Hi Jim,
you can use the Cisco 350 Wireless Bridge on your main building and on each of your other buildings also a 350 Wireless Bridge. In addition you will need antennas for the bridges. Here you can find a data sheets, to select the best antenna: http://www.cisco.com/en/US/products/hw/wireless/ps469/index.html
Philipp
ndoshi
You can have one point to multipoint bridge network or if possible break in to
two point to multipoint scenario .
I would recommend to do site survey also .
You can have
2 BR - ( non root )-----1 Br ( root ) -----1 BR ( root )---------2 BR ( non root)
Or have one single point to multipoint .
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Internetworking:Wireless_LAN_General&viewall=true
If you have all the bridges in linear fashion
non root ----root ---Wire connection ---non root ------root .
a) Keep Coax cable as short as poosible
b) Here is the antenna guide
Data sheet for Antenna :
http://www.cisco.com/warp/public/cc/pd/witc/ao340ap/prodlit/airoa_ds.htm
Antenna Reference Guide :
http://www.cisco.com/warp/public/cc/pd/witc/ao350ap/prodlit/agder_rg.htm
c) Have proper seal like coax seal .
Nilesh
manjeets
Level 5
Level 5
