Multiple Mobility Express Controller on Same Network
hi, I have a 1562i access point that I want to use as a controller but in the same location I have installed another ME Controller with the same type of AP. Is it possible to deploy the same 2 ME Controller in one network?
Mark Elsen
 - FYI : https://community.cisco.com/t5/wireless/two-cisco-mobility-controller-on-the-same-network/td-p/3299781
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Arshad Safrulla
PFB doc
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_01001.pdf
Please take extra caution if you have VRRP running on the network. once done to verify configuration sync between master and standby you can use
show mob-exp config-sync status
