Multiple SSIDs anchored to same WLC
A scenario I hadn't run across before.
The customer has an existing Foreign-Anchor WLC set up with their Guest WLAN running across it.
They want the new BYOD service to do the same thing (not sure the point of it).  When I anchor the WLAN to the Anchor WLC and test, the mobility tunnel sets up fine, but it directs the client to the Guest WLAN on the Anchor WLC, not the BYOD WLAN.
Is this a limitation on the WLC?  Like i said, never specifically configured this scenario, don't know why they want it this way, and can't find any documented caveats or limitations to this specifically.
thanks in advance,
Andrew
0 Replies 0
