Multiple WLAN VLAN's to a single Wired VLAN
a.mayat
Does anybody know if it is possible to map multiple WLAN VLAN's and still map these to a single VLAN on the wired network?
I would like to create VLAN's with different levels of security for WLAN clients (PEAP with OTP and Static WEP) and have these users going to a single VLAN. IS this possible?
Not applicable
I think you cannot map multiple Wlan Vlans to a single VLAN.
You can define a security policy for each VLAN on the access point.
This enables you to define the appropriate restrictions for each VLAN you configure. You can see the guidelines for Wireless VLAN Deployment in the follwoinh location:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch4.htm#1036528
