Need AP recommendation
malberttoo
Level 3
Level 3
Gurus,
I have several 7921's that I use, connected to 1130 AP's.  My 7921's only get about 10 feet of range once outside, and I need to increase that.
Can you all recommend an outdoor AP that I can mount on the building outside wall, so my phones will get better range?
-Michael
6 Replies 6
Leo Laohoo
1250 or 1260.
weterry
Level 10
Level 10
Unified (lightweight) or Autonomous?
Mesh is the only AP I know of that can be mounted outside with no special enclosures that is dual band....
But if your voice deployment is B/G only,  and/or you are autonomous, you could consider the 1310's if that product is still alive.
Other than that, as Leolaohoo said,  you could stick a 1260 outside, but you'd need a NEMA enclosure for it...
Thanks for clarifying that. My APs are all autonomous (I only have a few).
It looks like the 1310's are still easy to get, I'm going to look at that I think. The 1260 is cheaper, but I think for the moment I'm going to try to stary away from having to mount something in an enclosure.
-Michael
Just be wary that the 1260 requires external antenna and will support a maximum of -6 dBi while the 1250 can support higher gain antenna.
Great, thank you for the info!
-Michael
migilles
In regards to the 1500 series, VoWLAN is best effort support only.
