Need configuration guide for EAP-TLS
lbarisdale
Community Member
I need to setup the AP-1200 I have for EAP-TLS. Anyone know of some good documentation that I can use to configure this? I already have the CA and RADIUS servers up and going.
Thanks in advance for your help.
cdeeds
Here are some docs that I used when setting up EAP-TLS with my Cisco 350 APs and Cisco 340/350 wireless client adapters. I made notes in them but they were derived from Cisco support originally. I've found that Win2K clients have more trouble with authenticaion because they must have the 802.11x engine installed (MS update/hotfix) which I've found only can be installed on clients running SP3 (not SP2 or even SP4). Kinda weird. Anyways, you'll probably have the best luck with XP clients because of its native 802.11x support that's built in.
Hope that helps...
Thanks for the info cdeeds. I was looking for configuration guide using the IOS version on the AP-1200 but I'll take a look at the documents.
