Need help configuring wireless controller with multiple access points
Kryztian7
Community Member
I've been assigned the task of configuring the WLAN for a new three-floor building. We have a Cisco 2504 wireless controller and a couple of Aironet 2600 access points. Our access switches are 2960-S with PoE. We have diferent VLANs configured to segment the network.
My goal is to have two Extended Service Set SSIDs: Corporate (VLAN 50), and Guest (VLAN 60).
Also, I would like the wireless controller to be part of our management VLAN (VLAN 40).
I followed this intructions: http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml
but the access points are not registering with the controller.
Those instructions are for Lightweight Access Points, thou.
I've been looking around for some other instructions but can't find anything.
As you may noticed this is my first time configuring a wirelless controller. Please help out with this. I will really appreciate it.
Kryztian7
Community Member
Ok. Just figured out that I have to add an option 43 to my Microsoft DHCP server. I did that and now the AP is finding the WC but I am getting these error messages on the console of the AP:
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (10.2.8.10)
*Mar  1 00:29:21.055: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:29:21.055: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:29:31.055: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'H1-WC'running version 7.0.220.0 is rejected.
*Mar  1 00:29:31.055: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:29:31.055: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:29:31.055: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:29:31.055: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.2.4.8
*Mar  1 00:29:41.055: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'H1-WC'running version 7.0.220.0 is rejected.
*Mar  1 00:29:41.055: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:29:41.055: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:29:41.055: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:29:41.055: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.2.4.8
*Mar  1 00:29:51.055: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'H1-WC'running version 7.0.220.0 is rejected.
*Mar  1 00:29:51.055: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:29:51.055: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:29:51.055: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:29:51.055: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.2.4.8
Not in Bound state.
*Mar  1 00:30:06.555: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:30:09.563: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:30:09.627: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.2.12.167, mask 255.255.252.0, hostname APf872.ea23.b3a7
Thanks!
I think I will have to upgrade the IOS on the wireless controller.
Based on table 4 on this link: http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
version 7.0.2x.x does not support the 2600 series access points.
I will upgrade the IOS on the WC and see what happens.
