Need help in configuring Cisco
thenewcanvasco1
Community Member
I purchased a Cisco wireless device last week. I am struggling to configure this device. It is connected to the router but some systems are not connected to the internet. I am not a networking Engineer. Can you please share some resources blog posts or videos to help me in solving this problem? It is showing an Error transforming the image to express mobility
thenewcanvasco1
Community Member
Is there any specific configuration of Cisco AIR-AP1815W-B-K9  (www.allhdd.com/cisco-air-ap1815w-b-k9-access-point/)
                - Is it (already) running a mobility express image ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
It will depend to some extent on what version of software the AP is running and what mode the AP is in currently.  To be honest I don't think this product is well suited to somebody without some basic networking and Cisco knowledge.  Even worse the 1815W has a non-standard console port so you need a special Cisco adapter to connect a console cable.  Guides:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/user_guide/b_ME_User_Guide_810.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide.html
https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/mobility-express/q-and-a-c67-734485.html
You'll find other info on Cisco web site as well as various other places if you search.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
