Dear Friends,
I require that whenever any guest select Wi-Fi SSID, he/ she should get authentication portal on his/ her device automatically which means he should not need to open browser manually on his/ her device to just enter his/ her credentials. He should get browser automatically when he'll select SSID first time to use Wi-Fi for network access.and then he/ she should be able to access the network after passing an authentication. I have configured Cisco WLC 5508 and ISE version 2.1, I have configured User ID's into Cisco ISE and mapped Cisco ISE with WLC 5508. I am using External Web Authentication option into WebAuth field of Cisco WLC 5508. Cisco ISE is behaving as external web authentication. Right now scenario is I need to open browser manually and whenever I type any URL into my device's browser then it redirects me to my ISE server for an authentication but I want which I stated above.
