Need help on generating heat map for installation of Access Points.
SyedAdnan2643
Hello Guys,
I need help on installation of Access Points, as i'm new to access point I heard that first heat map should be generated using a floor maps then,after having heat map we can position the access points, I don't know how to generate it or which software to use, please help.
Thanks.
Sorry Ekahau Heatmapper will only show what the existing (installed) coverage is.
The difference between the two is the heatmapper is really designed to give people a cut down survey tool for single office space/ homes. Where as the Site Survey is designed for planning and more enhanced survey features.
Around learning Ekahau there are multiple quick how to videos and blog pieces available on their site.
https://www.ekahau.com/training/videos-guides/
For formal training their ESCE Course: https://www.ekahau.com/training/certification-courses/
If you reach out to Ekahau they will be able to hook you up with a demo copy more than likely, which should give you the ability to give it a test run. https://www.ekahau.com/products/ekahau-site-survey/evaluate/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
5 Replies 5
The generation of a heat map is really called a wireless design.
These are done to ensure that coverage and capacity is going to be meet before physically installing the access points.
The software I use to do this is Ekahau Site Survey. That being said if you are only doing a one off design/ install the software does have a price tag attached to it.
If you have Cisco Prime and you are only doing a one off you could use the wireless planning tool within it:
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-2/user/guide/bk_CiscoPrimeInfrastructure_3_2_0_UserGuide/bk_CiscoPrimeInfrastructure_3_2_0_UserGuide_chapter_0111.html#task_C11E19DC3022446BA3F09F0D0E14D537
That being said Prime is not as good as Ekahau.
The other option if you are only doing a small non complex space is look at Ekahau HeatMapper
Hope this helps
Thanks, Yeah,I've seen Ekahau Heatmapper, but i don't know how it works as the i'm totally new to Wireless World, apart from this is there any way to add access points models in it? and do i really need Ekahau Site Survey ? i'm already having Ekahau Heatmapper but, i guess it's not that helpful. check the screenshot, it will help you to understand my problem.
I don't know how to use Ekahau Is there any possible way that i can learn?
what's the difference between Ekahau Heatmapper and Site Survey ?
Thanks Highly appreciate.
Both are different products, if you looking pro version it has everything (Ekahau Sidekick™ Pro Pack)
BB
Thanks mate, It worked.
I downloaded the Ekahau Site Survey. Truly an amazing tool.
