Need Help Setting Up 1850 & 1830 Access Points
RCorr35672
I am completely new to Cisco and networking and I've been tasked with setting up a new WIFI system for my company, I am in a test environment currently and need to get it working before I start to deploy the access point around the building. To start, I have 2 AIR-AP1852I-B-K9 access points that I want to connect. I have gotten one of the Access Points easily set up as the Master through the Mobility Express GUI online but am struggling with getting my second AIR-AP1852I-B-K9 to connect to the first one. Eventually I have like 6 more 1832 Access Points I also need to connect to this master AP. I checked and the two 1852's are running the same software image 8.5.131.0. Here is the error I'm getting in the CLI from the second AP trying to join the master.
[*06/05/2018 07:26:38.3449]
[*06/05/2018 07:26:38.3449] CAPWAP State: Discovery
[*06/05/2018 07:26:38.3449] Discovery Response from 192.168.76.10
[*07/18/2019 12:54:12.0000] can't find the Ip from discoveryRequest array
[*07/18/2019 12:54:12.0000] CAPWAP State: DTLS Setup
[*07/18/2019 12:55:09.0222] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/18/2019 12:55:09.0222] CAPWAP State: DTLS Teardown
[*07/18/2019 12:55:13.7707] No more AP manager addresses remain..
[*07/18/2019 12:55:13.7707] No valid AP manager found for controller '1850 AP' (ip: 192.168.76.10)
[*07/18/2019 12:55:13.7707] Failed to join controller 1850 AP.
[*07/18/2019 12:55:13.7707] Failed to join controller.
[*07/18/2019 12:55:13.8907]
[*07/18/2019 12:55:13.8907] CAPWAP State: Discovery
[*07/18/2019 12:55:13.8907] IP DNS query for CISCO-CAPWAP-CONTROLLER.villages.com
[*07/18/2019 12:55:13.9007] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/18/2019 12:55:13.9007] Discovery Response from 192.168.76.10
[*07/18/2019 12:55:23.0000] can't find the Ip from discoveryRequest array
[*07/18/2019 12:55:23.0000] CAPWAP State: DTLS Setup
[*07/18/2019 12:56:20.0222] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/18/2019 12:56:20.0222] CAPWAP State: DTLS Teardown
[*07/18/2019 12:56:24.7707] No more AP manager addresses remain..
[*07/18/2019 12:56:24.7707] No valid AP manager found for controller '1850 AP' (ip: 192.168.76.10)
[*07/18/2019 12:56:24.7707] Failed to join controller 1850 AP.
[*07/18/2019 12:56:24.7707] Failed to join controller.
Any and all help would be appreciated I've been looking around the internet for the past week and haven't had much luck finding a solution. Also, I'm not all that savvy yet with the CLI so implicit instructions of what to provide for help would be nice.
Ryan
5 Replies 5
patoberli
You might be hitting a software bug, but I'm not entirely sure.
Release notes: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/85/release_notes/b_ME_RN_85.html#resolved-caveats
Your Master should have two IP addresses configured, are they both in the same IP range?
Do you have the correct country selected in the ME configuration?
Could you maybe post the complete boot process of the second AP?
My suggestion is to upgrade the master with the latest 8.5 release and then also upgrade one of the problematic ones and hope for the best.
Thank you for the response,
My supervisor is currently working with cisco support to get the licence so I can try doing a software update to fix this.
But in the mean time:
-What exactly do you mean by the master having two ip addresses? The address for the controller is
192.168.76.100
-I do have the correct country selected in the ME config
-And here is the complete boot process of the second ap:
U-Boot 2012.07 (btldr release 30) (Mar 03 2017 - 19:13:24)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected MICRON MT29F2G08ABBEAH4 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:0], write_counter=27
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832/1852 detected...
Power Type: 802.3at POE detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
Specified BOOT: part1
Booting from part1
Read 1024 bytes from volume part1 to 45000000
Read 45192571 bytes from volume part1 to 45000000
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=500M-:64M@1280M console=ttyHSL1,9600n8 activepart=part1 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1500] CPU1: Booted secondary processor
[01/01/1970 00:00:00.2200]
[01/01/1970 00:00:00.2200] +++ hydra_ap_gpio_value =3
[01/01/1970 00:00:29.7808] ACPU PVS: 1
[01/01/1970 00:00:32.2701] buginf tty flushing thread started, ttyport=ef5b4890
[*01/01/1970 00:00:38.4781] buginf() enabled.
[*01/01/1970 00:00:38.4881] Made it into bootsh: Jun 5 2018 07:25:25
[*01/01/1970 00:00:38.4881] bootsh build T-eb8875394ad25c6d61b54b35d0937f2f9ded3dd6-geb887539-vipendya
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
error: open /dev/board-config
init started: BusyBox v1.23.2 (2018-06-05 07:04:31 PDT)
[*01/01/1970 00:00:41.9470] GCM-128 POST passed
[*01/01/1970 00:00:41.9470] GCM-256 POST passed
[*01/01/1970 00:00:42.1170] === 5G radio domain is 41, COPY 5G BDF files from non_ETSI_BDF folder ===
[*01/01/1970 00:00:42.3469] Active version: 8.5.131.0
[*01/01/1970 00:00:42.3469] Backup version: 0.0.0.0
Jan 1 00:00:42 FIPS[1595]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*01/01/1970 00:00:42.5468]
[*01/01/1970 00:00:42.5468] led pattern module start
[*01/01/1970 00:00:42.5968] AP1852I
[*01/01/1970 00:00:42.7068] nss_driver - Turbo Support 1
[*01/01/1970 00:00:42.7068] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:42.7368] NSS firmware booted
[*01/01/1970 00:00:42.7668] NSS firmware booted
[*01/01/1970 00:00:43.2066] Current value of FACTORY_RESET=0
[*01/01/1970 00:00:43.2266] Last reload time: Jul 11 23:12:39 2019
[*07/11/2019 23:12:39.0000] Setting system time Thu Jul 11 23:12:39 UTC 2019
[*07/11/2019 23:12:39.0699] device wired0 entered promiscuous mode
[*07/11/2019 23:12:39.1399] device wired1 entered promiscuous mode
[*07/11/2019 23:12:39.5498] stile module dp init successfully
[*07/11/2019 23:12:39.5498] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Jun 5 2018 at 07:22:59
[*07/11/2019 23:12:40.2296] miibus get eec92000!
[*07/11/2019 23:12:40.2696]
[*07/11/2019 23:12:40.2696] boot 2 build T-eb8875394ad25c6d61b54b35d0937f2f9ded3dd6-geb887539-vipendya board corsica mac 00:B6:70:64:44:40
[*07/11/2019 23:12:40.2796] Module: mbedtls .text=0xbf000000 data=0xbf007e18 bss=0xbf008070
[*07/11/2019 23:12:40.2796] Module: aptrace .text=0xbf00c000 data=0xbf018834 bss=0xbf018cc0
[*07/11/2019 23:12:40.2796] Module: led_module .text=0xbf020000 data=0xbf0204e0 bss=0xbf020b48
[*07/11/2019 23:12:40.2796] Module: qca_nss_gmac .text=0xbf024000 data=0xbf02abc4 bss=0xbf02b088
[*07/11/2019 23:12:40.2796] Module: qca_nss_drv .text=0xbf034000 data=0xbf04f9e8 bss=0xbf050798
[*07/11/2019 23:12:40.2796] Module: qca_nss_capwapmgr .text=0xbf071000 data=0xbf075acc bss=0xbf075c20
[*07/11/2019 23:12:40.2796] Module: nssmgrctl .text=0xbf07c000 data=0xbf07d70c bss=0xbf07da30
[*07/11/2019 23:12:40.2796] Module: proclikefs .text=0xbf083000 data= bss=0xbf083b40
[*07/11/2019 23:12:40.2796] Module: stile_lm_ft .text= data= bss=
[*07/11/2019 23:12:40.2796] Module: stile_lm_dp .text= data= bss=
[*07/11/2019 23:12:40.2796] Module: ipv6 .text=0xbfa10000 data=0xbfa40f40 bss=0xbfa427ec
[*07/11/2019 23:12:40.2796] Module: bonding .text=0xbfa5c000 data=0xbfa6d62c bss=0xbfa6da58
[*07/11/2019 23:12:40.2796] Module: lowmemorykiller .text=0xbfa7a000 data=0xbfa7a2c0 bss=0xbfa7a44c
[*07/11/2019 23:12:40.2796] Module: qca_nss_profile_drv .text=0xbfa7e000 data=0xbfa7f320 bss=0xbfa7f494
[*07/11/2019 23:12:40.2796] Module: scsi_wait_scan .text= data= bss=
[*07/11/2019 23:12:40.2796] Module: ssdk_reg .text=0xbfa88000 data= bss=0xbfa88838
[*07/11/2019 23:12:40.6995] Last reload reason : 0: unknown
[*07/11/2019 23:12:42.3090] __mm_init_module
[*07/11/2019 23:12:42.3589]
[*07/11/2019 23:12:42.3589] __ol_ath_attach() Allocated scn ee000480
[*07/11/2019 23:12:42.3789] ol_ath_attach interface_id 0
[*07/11/2019 23:12:42.3789] Chip id: 0x9, chip version: 0x1000000
[*07/11/2019 23:12:42.3789] Target Version is 1000000
[*07/11/2019 23:12:42.3789] Flash Download Address c0000
[*07/11/2019 23:12:42.3789] ol_transfer_bin_file: flash data file defined
[*07/11/2019 23:12:42.3789] Cal location [0]: 00000000
[*07/11/2019 23:12:42.3789] Wifi0 NAND FLASH Select OFFSET 0x1000
[*07/11/2019 23:12:42.3989] qc98xx_verify_checksum: flash checksum passed: 0x7b36
[*07/11/2019 23:12:42.3989] ol_transfer_bin_file 3979: Download Flash data len 12064
[*07/11/2019 23:12:42.4189]
[*07/11/2019 23:12:42.4189] Board data initialized
[*07/11/2019 23:12:42.4689] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*07/11/2019 23:12:42.4689] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*07/11/2019 23:12:42.4689] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*07/11/2019 23:12:42.5489]
[*07/11/2019 23:12:42.5489] [Flash] : Ignore Module param
[*07/11/2019 23:12:42.5489] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*07/11/2019 23:12:42.5689] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*07/11/2019 23:12:43.6785] HTC Rx: insufficient length, got:4 expected =8
[*07/11/2019 23:12:43.6785] Startup Mode-0 set
[*07/11/2019 23:12:43.6785] HTC Service:0x0300 ep:1 TX flow control disabled
[*07/11/2019 23:12:43.6785] HTC Service:0x0100 ep:2 TX flow control disabled
[*07/11/2019 23:12:43.6785] Firmware_Build_Number:70
[*07/11/2019 23:12:43.6785] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffaa
[*07/11/2019 23:12:43.6785] RES CFG Support wmi_service_bitmap 9778
[*07/11/2019 23:12:43.6785] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*07/11/2019 23:12:43.6785] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*07/11/2019 23:12:43.7485] wmi_ready_event_rx: WMI UNIFIED READY event
[*07/11/2019 23:12:43.7485] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
[*07/11/2019 23:12:43.7585] ACS not enabled
[*07/11/2019 23:12:43.7585] ol_ath_thermal_mitigation_attach: --
[*07/11/2019 23:12:43.7585] __ol_ath_attach() Allocated scn ecec0480
[*07/11/2019 23:12:43.7685] ol_ath_attach interface_id 1
[*07/11/2019 23:12:43.7685] Chip id: 0x9, chip version: 0x1000000
[*07/11/2019 23:12:43.7685] Target Version is 1000000
[*07/11/2019 23:12:43.7685] Flash Download Address c0000
[*07/11/2019 23:12:43.7685] ol_transfer_bin_file: flash data file defined
[*07/11/2019 23:12:43.7685] Cal location [1]: 00004000
[*07/11/2019 23:12:43.7685] wifi1 NAND FLASH Select OFFSET 0x5000
[*07/11/2019 23:12:43.7885] qc98xx_verify_checksum: flash checksum passed: 0xf21f
[*07/11/2019 23:12:43.7885] ol_transfer_bin_file 3979: Download Flash data len 12064
[*07/11/2019 23:12:43.8085]
[*07/11/2019 23:12:43.8085] Board data initialized
[*07/11/2019 23:12:43.8585] ol_ath_download_firmware :First OTP download and Execute is good address:0x9c00 return param 4660
[*07/11/2019 23:12:43.8585] ol_ath_download_firmware:##Board Id 7 , CHIP Id 1
[*07/11/2019 23:12:43.8585] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_v2_007.bin
[*07/11/2019 23:12:43.9385]
[*07/11/2019 23:12:43.9385] [Flash] : Ignore Module param
[*07/11/2019 23:12:43.9385] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*07/11/2019 23:12:43.9684] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*07/11/2019 23:12:44.6782] FWLOG: [48903] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:44.6782] FWLOG: [48903] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:44.6782] FWLOG: [48903] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:44.6782] FWLOG: [48903] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:45.0681] HTC Rx: insufficient length, got:4 expected =8
[*07/11/2019 23:12:45.0681] Startup Mode-0 set
[*07/11/2019 23:12:45.0681] HTC Service:0x0300 ep:1 TX flow control disabled
[*07/11/2019 23:12:45.0681] HTC Service:0x0100 ep:2 TX flow control disabled
[*07/11/2019 23:12:45.0681] Firmware_Build_Number:70
[*07/11/2019 23:12:45.0681] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339b79b2 vht_supp_mcs:0x0000ffaa
[*07/11/2019 23:12:45.0681] RES CFG Support wmi_service_bitmap 9778
[*07/11/2019 23:12:45.0681] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*07/11/2019 23:12:45.0681] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*07/11/2019 23:12:45.1381] wmi_ready_event_rx: WMI UNIFIED READY event
[*07/11/2019 23:12:45.1381] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 1
[*07/11/2019 23:12:45.1481] acfg_attach: Offload using existing sock ee4edc00
[*07/11/2019 23:12:45.1481] ACS not enabled
[*07/11/2019 23:12:45.1481] ol_ath_thermal_mitigation_attach: --
[*07/11/2019 23:12:45.1981] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
[*07/11/2019 23:12:46.0778] FWLOG: [50287] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:46.0778] FWLOG: [50287] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:46.0778] FWLOG: [50287] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:46.0778] FWLOG: [50287] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*07/11/2019 23:12:46.0778] FWLOG: [50295] UNKNOWN 22:55 ( 0x3a, 0x10, 0x0, 0x10, 0x0 )
[*07/11/2019 23:12:46.9475] pid 2450's current affinity mask: 3
[*07/11/2019 23:12:46.9475] pid 2450's new affinity mask: 1
[*07/11/2019 23:12:49.4967]
[*07/11/2019 23:12:49.4967] Click sched monitor: schedulers = 1
[*07/11/2019 23:12:49.8866] click-config/io-real.click:131: While configuring 'todev_wired0 :: ToDevice':
[*07/11/2019 23:12:49.8966] warning: device 'wired0' is down
[*07/11/2019 23:12:49.9566] click-config/io-real.click:131: While configuring 'fromdev_wired0 :: FromDevice':
[*07/11/2019 23:12:49.9566] warning: device 'wired0' is down
[*07/11/2019 23:12:53.0556] click-config/io-real.click:131: While initializing 'tohost_wired0 :: ToHost':
[*07/11/2019 23:12:53.0556] warning: device 'wired0' is down
[*07/11/2019 23:12:53.5654] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*07/11/2019 23:12:54.6551] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*07/11/2019 23:12:54.6751] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*07/11/2019 23:12:54.6851] ip6_port srcr6, ip6local fe80::2b6:70ff:fe64:4440, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 3(slaac)
[*07/11/2019 23:12:55.0550]
[*07/11/2019 23:12:55.0550] phy_value=0: org="0x1000" phy_reg="0x1000"
[*07/11/2019 23:12:55.2649] wired0: 100 Mbps Full Duplex
[*07/11/2019 23:13:03.0725] Loading sha2...
[*07/11/2019 23:13:03.0725] Dumpping sha1...
[*07/11/2019 23:13:04.7220] Loading MIC cert and key
[*07/11/2019 23:13:04.7220] Dumpping sha2...
[*07/11/2019 23:13:06.4415] Loading MIC cert and key
[*07/11/2019 23:13:06.8213] Generating key, this may take a while...
[*07/11/2019 23:13:10.9401] Public key portion is:
[*07/11/2019 23:13:10.9401] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCb0cWndNuGghPvGq6Gsz+rD6CvLSK7YEn03rHA2INtnRfUAy4FoQ4Kk1XzVWMwPuezyvLoRCqxi72IJzlOhFdtmNP2NhaI20eIRug0FnNXvNRVZkT3Jn7ndEf9EUV8k/XGdLC+VKRLWX9S1aRrDf35qNwCldfZxhEZBlFzw2ww1WVBpQ3+K1oMSkJ6E0qztL/fpILubRqRSAdaleKNYV/hhzbPgSST10rO6/42VX/fI3pQk6FcaSdr9z+Q52uxD7fOQ0sJ9JP5Bo292JbZsrL0QgqZr4OKtbHmD4zVxOhRR8MsT78F2io2zPjFRM8TAlzFbwweZfcyNOGD+CnjXR9b root@m00B670644440
[*07/11/2019 23:13:10.9401] Fingerprint: md5 64:55:21:5b:6f:c0:07:e7:fa:5a:15:7e:51:7c:9a:ab
[*07/11/2019 23:13:11.0000] pid 3964's current affinity mask: 3
[*07/11/2019 23:13:11.0000] pid 3964's new affinity mask: 1
[*07/11/2019 23:13:11.4799] Password for 'Cisco' changed
[*07/11/2019 23:13:11.6099] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/0/g' -e 's/__DOMAIN_5G__/41/g' -e 's/__PWR_TABLE_49G__/0/g' -e 's/__PRODUCT_ID__/AIR-AP1852I-B-K9/g' -e 's/__AP_TYPE__/48/g' -e 's/__WIRELESS_MAC__/00:B6:70:65:5E:00/g' -e 's/__WIRED_MAC__/00:B6:70:64:44:40/g' -e 's/__WIRED1_MAC__/00:B6:70:64:44:40/g' | DMALLOC_OPTIONS=debug=0x400003,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*07/11/2019 23:13:12.9794] DOT11_DRV[0]: Init Radio0
[*07/11/2019 23:13:13.0094] DOT11_DRV[0]: Stop Radio0
[*07/11/2019 23:13:13.0094] DOT11_DRV[0]: set_channel Channel set to 6
[*07/11/2019 23:13:13.0194] DOT11_DRV[1]: Init Radio1
[*07/11/2019 23:13:13.0494] DOT11_DRV[1]: Stop Radio1
[*07/11/2019 23:13:13.0494] DOT11_DRV[1]: set_channel Channel set to 36
[*07/11/2019 23:13:13.7092] DOT11_CFG[0] Radio Mode is changed from Local to FlexConnect
[*07/11/2019 23:13:13.7192] DOT11_DRV[0]: Start Radio0
[*07/11/2019 23:13:13.7192] DOT11_CFG[1] Radio Mode is changed from Local to FlexConnect
[*07/11/2019 23:13:13.7192] DOT11_DRV[1]: Start Radio1
[*07/11/2019 23:13:13.7192] DOT11_DRV[0]: Stop Radio0
[*07/11/2019 23:13:14.1191] DOT11_DRV[0]: set_channel Channel set to 1
[*07/11/2019 23:13:14.1191] DOT11_DRV[0]: Start Radio0
[*07/11/2019 23:13:14.1191] DOT11_DRV[0]: Channel set to 1, width 20
[*07/11/2019 23:13:14.1291] DOT11_DRV[0]: Stop Radio0
[*07/11/2019 23:13:14.5289] DOT11_DRV[0]: Channel set to 1, width 20
[*07/11/2019 23:13:14.5289] DOT11_DRV[1]: Stop Radio1
[*07/11/2019 23:13:14.5489] DOT11_DRV[1]: set_channel Channel set to 36
[*07/11/2019 23:13:14.5489] DOT11_DRV[1]: Start Radio1
[*07/11/2019 23:13:14.5489] DOT11_DRV[1]: Stop Radio1
[*07/11/2019 23:13:14.9388] DOT11_DRV[1]: Start Radio1
[*07/11/2019 23:13:14.9388] DOT11_DRV[1]: Channel set to 36, width 20
[*07/11/2019 23:13:14.9488] DOT11_DRV[1]: Stop Radio1
[*07/11/2019 23:13:14.9588] DOT11_DRV[1]: Channel set to 36, width 20
[*07/11/2019 23:13:14.9588] Failed to load flex AP config from file. Default config will be used.
[*07/11/2019 23:13:14.9688] ip6_port srcr6, ip6local fe80::2b6:70ff:fe64:4440, ip6 ::, plen 0, gw6 fe80::c2ea:e4ff:feea:97f4, gw6_mac C0:EA:E4:EA:97:F4, mtu 1500, vid 0, mode6 3(slaac)
[*07/11/2019 23:13:18.9776] Waiting for uplink IPv4 configuration
[*07/11/2019 23:13:18.9875] ethernet_port wired0, ip 192.168.21.226, netmask 255.255.255.0, gw 192.168.21.1, mtu 1500, bcast 192.168.21.255, dns1 192.168.21.26, dns2 192.168.22.26, domain villages.comAP IPv4 Address updated from 0.0.0.0 to 192.168.21.226
[*07/11/2019 23:13:29.9841] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*07/11/2019 23:13:29.9841] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*07/11/2019 23:13:30.0341] dtls_init: Use MIC certificate
[*07/11/2019 23:13:30.0341] CAPWAP State: Init
[*07/11/2019 23:13:30.0341] PNP is not required, Starting CAPWAP discovery
[*07/11/2019 23:13:30.0341] CAPWAP State: Discovery
[*07/11/2019 23:13:30.0341] IP DNS query for CISCO-CAPWAP-CONTROLLER.villages.com
[*07/11/2019 23:13:30.0441] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/11/2019 23:13:30.0441] CAPWAP State: Discovery
[*07/11/2019 23:13:30.0441] Discovery Response from 192.168.76.100
[*07/19/2019 15:20:14.0000] can't find the Ip from discoveryRequest array
[*07/19/2019 15:20:14.0000] CAPWAP State: DTLS Setup
[*07/19/2019 15:21:11.0122] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/19/2019 15:21:11.0222]
[*07/19/2019 15:21:11.0222] CAPWAP State: DTLS Teardown
[*07/19/2019 15:21:15.7707] No more AP manager addresses remain..
[*07/19/2019 15:21:15.7707] No valid AP manager found for controller '1850 AP2' (ip: 192.168.76.100)
[*07/19/2019 15:21:15.7707] Failed to join controller 1850 AP2.
[*07/19/2019 15:21:15.7707] Failed to join controller.
[*07/19/2019 15:21:15.7707] CAPWAP State: Discovery
[*07/19/2019 15:21:15.7707] IP DNS query for CISCO-CAPWAP-CONTROLLER.villages.com
[*07/19/2019 15:21:15.7807] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/19/2019 15:21:15.7807] Discovery Response from 192.168.76.100
[*07/19/2019 15:21:25.0000] can't find the Ip from discoveryRequest array
Please check IP configuration, they don't seem to be in the same vlan/network.
What do I need to check/change in order to fix this?
Thanks for replying quickly
Either put both devices into the same vlan or configure a router for both ip ranges. I suggest putting both into the same vlan.
