Need help with Aironet 340
rhirvela
I have Aironet 340 Ap, which should be able to communicate with nokia c110 wlan card. I can see the Cisco Ap from Nokia's client application, but Cisco Ap won't associate Nokia client. Is there some setting in aironet that should be turned on/off. I think that I've tried almost anything, but no success yet. Because they both are Wi-Fi certified products I think they should work together.
a-vazquez
Level 6
Level 6
Yes they should be inter-operable. If you’ve double-checked and triple-checked your configs from spids to WEP, you might need tech support as the next step. Try disabling WEP first to see if you can associate without encryption.
ED CARMODY
Level 4
Level 4
The Cisco 340 Series AP can emulate a straight 802.11b Access Point. This is a checkbox that you turn on in the AP. You probably need to do this.
s.rupeikis
Its works, just disable WEP nd enable long wawe heders
