Need help with setting up wireless on a C897
mohanish12
I am trying to set up Wireless on a C897.
But the Dot11radio 0 interface isnt coming up.
Its giving an error stating "Mar 1 05:08:26.014: %DOT11-4-NO_SSID_VLAN: No SSID with VLAN configured. Dot11Radio0 not started."
PFA the configs of both the router and the AP.
Please if someone can help me out in getting the Wireless up and running.
Saurav Lodh
Level 7
Level 7
Removing the SSID from the global config first, causes the SSID to be removed from the radio interface. If you remove the SSID this way the AP WILL NOT crash.
